There seems to be some issues with selecting tool libraries from the Tool Library Tree.
The check marks don't work properly, sometimes they show up orther times they do not.
This happens mostly with the Document library.
The tool libraries also have issues once the above happens when you try to open another library you check the box and no tools are displayed.
It could be I am not useing it correctly, is there any info on how the new tool library should be used and operate?
Thank you.
Yes, I have had some temperamental issues with the new Library. I chalked it up to not clicking the proper order when doing things. In other areas, I've submitted bug reports for obvious problems.
Try X-ing out of the Library and going back into it, I found that cured most of my issues
That is correct. If you look at your right side of the Fusion forum, you will see this:
But please, for the love of all that is holy, make sure you actually have a bug, and not just dealing with getting stuck on how to do something. First recourse for me, has always been the forum. Most of the "usual's" are quite active and more than willing and able to sort most problems out
And please when reporting let us know if you’re on a MAC or PC.
You got it Chief!
I'm using a PC with windows 10.
Thank you for all your help.
