my machine only takes files with the ending ".PM" . In the post processing there is only the ending ".NC" for MillPlus.
Can I change that somehow?
Many thanks in advance!
Hallo,
meine Maschine liest nur Dateien mit der endung ".PM". In dem Post Prozessor gibt es für MillPlus jedoch nur die endung ".NC".
Kann ich das irgendwie ändern?
Vielen Dank im voraus!
Solved by LibertyMachine. Go to Solution.
Open up your post .cps file.
Find this line, right near the beginning (line 20):
extension = "nc";
and change it to this:
extension = "pm";
That's it!
Do note: DO NOT save the modified post in the generic post location. It will be overwritten at the next update. Save it to the cloud or a folder that you've created elsewhere on your computer.
