If You're New To Turning in Fusion CAM, you might want to take a look at these new tutorials from the Content Experience Development (CXD) team.
Introduction To 2D Turning is a process based lesson plan, that takes you from the beginning to the end of programming a complete part. While you can jump to a specific lesson for quick information, it's advised that you go thru the entire series, from beginning to end.
Each step/page of the lesson process is fully documented and includes video instruction.
Always looking for feedback. Tell me what you think of these types of lessons.
@brianrepp sticky requested?
Is a lesson on tool orientation and setup possible? The Turret orientation isn't allowing me to place tools in the X- for gang tooling setups. I can set tools up parallel to the stock and have success, But i can only set up tools from X + (In a turret) My Tormach is set up for gang only at the moment so i can not use CAM to generate tool paths with the tool oriented the same as the machine.
i am very new to fusion 360 and i also have questions about tools.. however i saw your post and dont even know if it is valid anymore but something i saw when i went in to edit a tool was a section that had tool orientation in it if that might help at all.. i would also like to see some tutorials on creating tools and what to do if fusion will not let you create a tool that you have sitting in front of you.
You succed to place the tool in X, Y... for lathe?
Have a nice day!
Thanks Tim,
We also have a series on Turning with live tooling and sub-spindle transfer.
