Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
How to move tool turret to safe position
2 REPLIES 2
Carbidecnc
334 Views, 2 Replies
Hi Guys
I would like to move my turret to safe position in the ''x ''when doing a tool change so my longest tool does not hit the work piece.Im using SIEMANS CONTROLLER.
2 REPLIES 2
stniesen
in reply to: Carbidecnc
At the end of that tool's CAM path, in the post processor, simply type in:
G54 X-15.000
This is assuming you're using a standard G54 offset, and the -15.000 is simply an example. You can jog your machine to the spot you want the tool to change to see exactly what X value you should use, and this will prevent an error during a tool change if your value is too large for the table. You'll use this both before and after your long tool.
Carbidecnc
Thanx
