Hey can anyone tell me how to disable the I and J coordinates in the output cam Program for FANUC
Solved by ivan.stanojevic. Go to Solution.
Solved by Aadithya01. Go to Solution.
Solved by LibertyMachine. Go to Solution.
Solved by George-Roberts. Go to Solution.
For XYZ motion or 4th axis movement?
If the former, there is a toggle at the Post Process screen; useRadius
Setting it to "Yes" will output "R's" instead of I and J
Or if you want to get rid of arcs altogether, in the post processor, change allowedCircularPlanes from undefined to 0. This will linearize all arcs
HEy @George-Roberts
For the fanuc post processor i dont have the option for allowedCircularPlanes ...
Hey @LibertyMachine @George-Roberts
Do you know how to disable T01 M06 line from the post program output for fanuc .. My customer had asked this .. cause his CNC machine doesn't have a tool magazine .. so is there any setting in Fusion 360 to disable the T01 M06 line.
I would look at the posts for the Mach3 or the Tormach. Both of those have toggles for "changeTools" or something to the effect
Of course, you could also brute force it and delete the section in RED
disableLengthCompensation(); writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6)); if (tool.comment) { writeComment(tool.comment);
@Aadithya01 wrote:
HEy @George-Roberts
Yes you have at the beginning of every post.
Ivan Stanojevic
I just did this
// writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
I just added the // backslahes and that worked . Many thanks @LibertyMachine
Hey @LibertyMachine @ivan.stanojevic@George-Roberts
T1 M06 is sucessfully diabled
How to disable H01 ... ??
Error(C:\POST PROCESSORS\fanuc.cps:1049): ReferenceError: f is not defined
After deleting H offset like you said it is saying the above error
Please see the attached fanuc post processor where I had made the change
