trying to post process with the generic Haas format and im getting some problems. every operation it calls up one tool at the beginning (N30) then after the tool length comp is added its trying to call up the next tool to run the operation (N70). simulation on fusion runs fine with correct tooling called up. it only seems to be on the post process that its doing it. Am i being stupid?
(Face3)
N30 T1 M6
N35 S265 M3
N40 G54
N45 M8
N60 G0 X25. Y-10.862
N65 G43 Z20. H1
N70 T2
N75 G0 Z10.
N80 G1 Z4.5 F40.
N85 X-25.
N90 G2 Y-0.838 I0. J5.012
N95 G1 X25.
N100 G3 Y9.186 I0. J5.012
N105 G1 X-25.
N110 G0 Z20.
N115 M5
N120 G53 G0 Z0.
Solved by LibertyMachine. Go to Solution.
This is the tool "precall". All it does is move the next tool (to run) into the waiting position. This would be used if your machine has a double arm ATC
If your machine does not have a tool changer, or it's an umbrella style tool carousel, you would want to set this switch to "No"
