I am not certain which dimensions are dropped into each tool criteria. This results in chamfers that don't look good. Could you please help me set up one chamfer tool. I can't find an example on youtube tool diameter is .25"
The beauty of 90 degree chamfer tools: The length of cut is always half the diameter, assuming the tool comes to a point and not a large flat.
So, setup your tool like this:
Ah, the cutter distance was messing me up. Used your information to work it backwards. Thank you so much.
http://www.1728.org/angsize.htm
