I have had issues with chamfering similar to the attached file number of times (fourth operation from the bottom), I don't know what I am doing wrong, tried different tip offsets, clearance amounts, etc... Sometimes it'll make two or three lead ins/outs on a single hole chamfer...It's super annoying for a simple op.
Solved by LibertyMachine. Go to Solution.
This is a bug, and it's been reported more than a couple of times ....cough... @jeff.pek, what's the status on this?
Turn the tolerance up, .001" will do the trick. This is found on the passes tab, at the top:
This sounds kind of similar to CAM-4561 and CAM-4639). I'll create a new specific issue to this report (with the file), and link them together. (CAM-6886)
This is on our "TODO" list -- this will elevate its priority a bit.
Jeff
