CAM doesn't respect changes made to model
Not working in Fusion that much until the past few days.
I've noticed this behavior in the past two projects.
Create a drawing to make my model. Make the model, do all those things we typically do, add fillets, trim a little here etc..
When I move to the CAM workspace, make my setup then begin to make tool paths.. it doesn't respect the last change I made. Whatever it was.
I've tried saving the project before going to CAM, deleting the operation, deleting the setup, closing and reopening the project before going to CAM, close and reopen Fusion.
Did the update drivers, clean out temp files, stop all unneeded services trick.. no dice.
The only thing that works is to reboot the computer.
I can't imagine this is working as intended.
Suggestions?
See photo for latest. Last feature to add were the fillets. It doesn't respect them no matter what I do. If I select the fillet it will show that as a separate chain but keeps the square corner chain as well.
