Fusion users looking to offer input into beta functions in our software can now do so by enabling BETA mode.
It is important to note, you must manually turn beta mode off.
Beta mode is only suggest for short term testing of new functionality.
Learn more about how to enable beta mode here:
http://manufacturinglounge.com/hsm-beta-mode-hsmwork-inventor-hsm-fusion/
When comment on CAM beta functions please do so in the CAM Beta forum to avoid confusion to users not using beta mode.
http://forums.autodesk.com/t5/beta-testing-english-deutsch/bd-p/219
Solved by al.whatmough. Go to Solution.
EDIT: Never mind, like a silly person I skimmed the instructions....I didn't have txt selected when I entered the command...thanks..
Hi @al.whatmough!
I was looking for this just the other day
I got an error trying to enable it though....
What did I do wrong?
Thanks!
Well this is pretty cool. Is there any documentation on what is in the Fusion CAM Beta so we can look out for new features we wouldn't otherwise be aware of?
As we release things in beta we let users know in the BETA Forum.
Randy Kopf
http://desktopartisan.blogspot.com/
Curious question: Is it safe to use Beta version? What I mean is: Features that already exist in "off-the-shelf" Fusion that are proven and known to work, will they still be the same, or does everything become "use at your own risk"
Or is it only the new features in Beta that are questionable?
Suppose you are using the default Python text command type. Try to change the text command type to be txt and input CAM.BetaMode /on again. See the attached picture for the details, please.
@LibertyMachine Everything becomes beta. Most other areas of the software should not be impacted. However, we do not gaurentee that there isn't work happening in the kernel for facing even if you don't see any new icons or options.
@al.whatmough what are the beta features in fusion cam is it the same as the vids you did showing what is in HSM
The link in the original post that is supposed to take you to a place that tells you how to turn on CAM Beta Mode in Fusion now results in an error saying that I'm not authorized to view that page. Is this what is now intended? Is CAM Beta Mode in Fusion no longer available to the general Fusion user base?
You can CTRL+ALT+C to show the text commands window, There you can select TXT as the input type in the lower right hand check box.
The enter - CAM.Betamode /on
@Trigg3r answered your question, but here's a quick visual. Usually the Text Commands section is minimized at the bottom:
Thanks, yes CTRL+ALT+X works to get the text box.
My intention in part was to point out that the link in the original post no longer works (for me at least). Maybe someone will be able to fix that for the benefit of the community.
@friesendrywall My apologies, I misunderstood.
@brianrepp can we get a working link? Does this even exist anywhere anymore? I haven't found it since (and I have checked several times since this post went up, although not in some time).
Updated link here:
