Hello Forum,
I am new to Fusion 360. We have Soldiworks 2014 in the shop. We would like to be able to import files/parts from Solidworks to machine with our CNC mill. I have tried IGES format for my first CNC project but is seems the part required the use of the PATCH command and selecting all the faces of the part to Stitch them together. This was in an earlier post, when I was getting some real weird reaction from Fusion when I tried to drill some holes in CAM.
So are there any guidelines or suggestions people have for importing SolidWorks files? I have searched the archive, but it is pretty thin.
Jgaertner
Solved by Steinwerks. Go to Solution.
STP should work better and keep solids solid and you have the option to use New Design From File. If you don't mind uploading through the Data Panel you could try uploading the sldprt file.
Mark
Mark Hughes
Owner, Hughes Tooling
Hello Forum,
So I did import the SW 2014 part into Fusion and everything worked very nicely.
Had a problem with the deep pocket milling strategy, but that is a different issue to pursue.
Thanks for the help!
Jgaertner
I'm trying the same thing and getting the error that the SW "Version of the file format is not supported" I don't know what rev level SW the customer is using but I don't want to have to force them to move it to a step file. This was one of the perks to Fusion 360 that i could open Solid works files.
Please hit me up with info if you can upload cleanly!!
Yup, still can't translate SW2017 files.
@al.whatmough is there any insight as to why this isn't working?
Good to know. Client has a deep love of Solidworks so it's no doubt he's got the latest and greatest. Now I'll have to grovel and tell him that yet again Solidworks has defeated me 😞 ;). I'll just get him to get me the stp files like a normal human being 😉
Another option that will probably be frowned on is to use Onshape to open the SW2017 file and export it yourself if you don't want to bother customers.
Hey if it works...
But really, his customer should stop being a twit and just send out step files in the first place. Forcing everyone else to specifically ask for neutral format files is stupid and wastes not only their time but also your own.
C|
I think a little bit of single format elitism 😞 or SFM as doctors are calling it. It's the denial that any other format can have any positives... tough times we live in 😉
I understand that SW 2017 will be supported in the upcoming April update.
Jeff
