I have a curved profile with multiple arc segments.....how do I select a single segment as opposed to the entire chain?
Solved by LibertyMachine. Go to Solution.
To select a partial segment, you can do one of a couple things:
1) Alt + Left Click. I prefer this one, as it gets you right to the solution without any extra clicking around.
2) Select the profile. Select it again, it will turn red. Select the little tiny box that pops up and select "open". Select "just" the one entity you want, click "Accept Contour"
Yeah, method #1 gets you there quicker
For some reason, I can't select any screencasts out of the Fusion forum dropdown menu, so I can only supply you with this link to one I made some time ago:
Thanks. Most of my programing experience is in esprit....I am learning Fusion now.
