Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Arc segment selection?
2 REPLIES 2
colemanVJMPP
253 Views, 2 Replies
I have a curved profile with multiple arc segments.....how do I select a single segment as opposed to the entire chain?
2 REPLIES 2
To select a partial segment, you can do one of a couple things:
1) Alt + Left Click. I prefer this one, as it gets you right to the solution without any extra clicking around.
2) Select the profile. Select it again, it will turn red. Select the little tiny box that pops up and select "open". Select "just" the one entity you want, click "Accept Contour"
Yeah, method #1 gets you there quicker
For some reason, I can't select any screencasts out of the Fusion forum dropdown menu, so I can only supply you with this link to one I made some time ago:
https://knowledge.autodesk.com/support/fusion-360/getting-started/caas/screencast/Main/Details/d0a64...
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Thanks.  Most of my programing experience is in esprit....I am learning Fusion now.
