Introduce myself
Introduce myself
Introducing myself
Hello everyone, my name is Manuel De La Torre Ruiz, I'm from Mexico, actually I'm looking for a job position on design engineer because I finished the university Engineer on Mechanical Design.
I'm a new user of Fusion 360, I used to use SolidWorks but I want to learn more about Fusion 360 and obtain a certificate on CAM with this software because I used to work in a machine shop as machining technician also I want increase my hability to create design.
I hope learn a lot and be helpful for another ones giving some advices about desing.
Thomas_Savage
Hello @Anonymous
Welcome to the forum.
I have attached a link to the Fusion 360 forum.
Where you can learn, ask any questions, or share any problems you may have using Fusion 360.
https://forums.autodesk.com/t5/fusion-360/ct-p/1234
Thomas.
Thomas Savage
Design Engineer
Thanks @Thomas_Savage for attachment the link.
I left a question that I hope someone can solve me, also I will spend some time reading some posts to see what are discussing in the forum.
Thomas_Savage
You're Welcome.
Hope you get your answer solved.
Thomas.
Thomas Savage
Design Engineer
arturopolanco
Hola Manuel, nos alegra tambien disponer de una Comunidad de Autodesk en Español con un foro especial en Fusion 360.
Te invitamos a participar tambien en tu idioma y compartir con nuestros especialistas.
Enlace: https://forums.autodesk.com/t5/fusion-360-espanol/bd-p/337
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Youtube | Twitter
Hola @arturopolanco, el link de la comunidad de Autodesk en español me dice que puede haber sido borrado, te agradecería si pudieras reenviarlo o revisarlo.
De antemano muchas gracias.
arturopolanco
Hola @Anonymous aqui esta el enlace: https://forums.autodesk.com/t5/fusion-360-espanol/bd-p/337
Verifica si te funciona correctamente.
Por si necesitas otro enlace: https://forums.autodesk.com/t5/espanol/ct-p/157
Ese ultimo es de todos los foros en Español.
Saludos!
Arturo Polanco
Youtube | Twitter
