Do you want to understand how Dynamo performs under the hood? Do you want to know all the levers you can pull to make Dynamo perform as fast as it can? Do you want to geek out and talk all things technical in Dynamo? Then come join Jacob and Sol as we dive into the worlds of execution, tessellation, rendering, marshalling and compliation! And if all that stuff sounds a little too much, then don’t worry as well leverage metaphor and storytelling to explain what matters and how you, as a user, can interact with Dynamo to get all that you can out of it! We’ll explore both Settings and node based options to make your Dynamo graph sing, as well as exploring display options, discuss inline vs. multi-line functions and what function passing is, and refresh on delta-compute and how it helps graph execution.
This session will be also be supported by an Autodesk Community Manager as part of Community Conversations - live, virtual events designed to allow you to gain expertise, connect with leaders and grow your community network.
Come join Jacob and Sol as we explore how you can tame the chaos of a large, unwieldy monster graph! We will take a Dynamo graph that has lots of copy-paste on node blocks, no annotation, and nodes and wires all over the place and take you on a journ...
Join Jacob and Sol for How to Make Dynamo Sing!
Do you want to understand how Dynamo performs under the hood? Do you want to know all the levers you can pull to make Dynamo perform as fast as it can? Do you want to geek out an...
Do you make really cool things and want to share them with others? Are you excited about empowering your peers and exponentially leveraging your time? Then come dive into the worlds of Sharing Dynamo content and Dynamo Player with Sol Amour, Jacob Sm...
Hang out with Jacob and Sol as we look under Dynamo's hood, diving into what %appdata% means, what a package is and how Dynamo talks to it, where to find packages and how to manage them as well as the differences between packages of the ZeroTouch, Py...
Come join Jacob and Sol on a journey through into how best to plan your Dynamo graph. We’ll explore how to flow chart your graph to plan ahead, look to incorporate speed optimizations to work efficiently, and touch upon the graph development pipeline...
With a program like Revit, we are always on the lookout for a new tip or technique to make our daily workflow go a little more smoothly. In this session we’ll build a dormer, create a layered viewport presentation, explore family cutting behavior, ad...
