Revit 2023: Revit Walls - An Alternative Approach to Design and Creation Series BONUS!!
Method 7 – Use Custom Adaptive Curtain Panels for Divided Surface
  • This method is more of an experiment on creating pattern systems using the Divide Surface command within the Conceptual Massing Environment and a custom adaptive curtain panel hosted by that divided surface.  This divided surface pattern is called Weave.  This particular one required A LOT OF MATH!  The key thing to remember in this method is that you are free to experiment custom panels with preset divided panels.
Pro Tip:  If you keep your divided panel divisions to a low number (less than 20 for each U, V, W system, the regeneration of the object will be much faster.  The higher the division number, the longer the processing time.
