Revit 2023: Revit Walls - An Alternative Approach to Design and Creation Series 6 of 6
Method 6 – Use Void Panels in Curtain Walls
  • This method is more of a “negative” method of creating custom panels.  Instead of making a solid extrusion in Method 5, you are create a void shape to define the placement of custom solid geometry to create the panel. The key thing to remember in this method is that you are adjusting the shape of the panel by modifying the void object.
Pro Tip:  You will need to use Join Geometry for the solid objects and sometimes the Cut Geometry for the void objects.
3 Comments
