If you've ever worked with Revit, you know it's a lifesaver for architects and engineers. One of its coolest features is making it easier to export your projects to PDF, especially when it comes to automatically naming files.
Why is this so useful?
Imagine having to export dozens or even hundreds of sheets from your project. Naming each one manually would be an endless and error-prone task. This is where Revit's file naming feature comes in. It allows you to define a naming convention that Revit will automatically follow.
How does it work?
When you export your views or sheets to PDF, Revit offers an option to configure the file name. You can use various predefined variables such as:
- Sheet Name
- Sheet Number
- Project Name
For example, you can set the file name to be something like Sheet Number - Sheet Name.pdf. Revit will automatically replace these variables with the correct information for each sheet.
Setting it up in Revit
Go to the "File" tab and select "Export."
Choose "PDF," or use the icon in the upper corner of Revit.
In the PDF export window, under "file," click on "file name."
In the Setup Naming Rules dialog, you can create your pattern using the available fields:
Revit's file naming feature when exporting to PDF is a handy tool for keeping everything organized and avoiding errors when naming your files. Besides saving time, it ensures your documents are always well identified. So next time you export, don't forget to set up this functionality and make your work even easier.
Sie müssen ein registrierter Benutzer sein, um hier einen Kommentar hinzuzufügen. Wenn Sie sich bereits registriert haben, melden Sie sich bitte an. Wenn Sie sich noch nicht registriert haben, führen Sie bitte eine Registrierung durch und melden Sie sich an.
