Over the years, AutoCAD has evolved its user interface to the point that some modern users argue that the command line is no longer necessary. This tip attempts to rebuke that by showing where old school methods may still be the best.
Many commands have a command line version. Just add a dash to the front of the command name to access them. Here are a few examples:
The Power is in the Wildcards
Just being able to access these on the command line doesn’t really help you much though. It’s more typing, manual data entry, proper syntax; in other words, no productivity gains at all (and possibly just the opposite).
The real power comes with using wildcards. Wildcards are special characters that can represent one or more characters in a text string. Below is a table that identifies the characters that AutoCAD recognizes, and what each one does.
Let’s look at a few ways of how you can use some of these wildcards in your commands.
-XREF B * Quickly Bind all the XREFs in your drawing (you could easily do the same with Unload, Reload or Detach)
-XREF U *ABC* Here we’re unloading only the drawings with ABC somewhere in the name
-PURGE B ~XYZ Y Purge only the blocks that do not have XYZ in their name.
-LAYER C 9 WEST*|A-* This last example is a little more complicated. Here, we’re setting any Architectural XREF dependent layer (note the use of the vertical bar) whose name starts with WEST to be color 9.
The first few examples are rather simple but may offer a more efficient way of performing the task. The final example is a lot more powerful. There are many ways to use command line versions in conjunction with wildcards to speed up tasks that modern interfaces may slow down.
(Bonus tip: Wildcard characters can be used in other places in AutoCAD, such as Find and Replace and Quick Select)
Summing up
While I do go back to those days when issuing commands via the command line was necessary knowledge, don’t get me wrong, I am a huge fan of the GUI improvements that have gotten us to the latest release.
But the next time you’re struggling to get one of the new, sleek palettes set up to your liking, you might try going old school with the command line. It may not be something you’ll do all the time, but when you need it, you’ll be glad you know how.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
