Command Your Vault Workflow: Essential Control Definitions in Inventor
Are you looking to automate and streamline your workflows in Autodesk Inventor? Control definitions hold the key to unlocking powerful commands and tools within Inventor, allowing you to customize and enhance your productivity. In this post, I'll show you how to export and identify control definitions, explore Vault-specific commands like Check-In, Check-Out, and Undo Check-Out, and configure dialogue suppression for seamless operations. Whether you’re using iLogic, VBA, VB.NET, or C#, this guide will provide practical examples and tips to harness the full potential of Inventor's control definitions. Join me as we dive into the details and take your Inventor automation to the next level!
Exporting Control Definitions
When working with Autodesk Inventor, control definitions are a powerful way to understand and automate commands within the application. These definitions represent the commands and tools available in Inventor's interface, including their names and internal identifiers.
The first step in leveraging control definitions is identifying them. This can be done by exporting all available control definitions to a text file. This straightforward process can be achieved using iLogic, VBA, or an external add-in written in VB.NET or C#. Below, we'll explore how to accomplish this in each of these environments.
Example 1: Exporting Control Definitions with iLogic
iLogic provides a simple scripting environment built into Autodesk Inventor. You can use it to quickly automate tasks, such as exporting control definitions.
Here’s an example of how to achieve this using iLogic:
Imports System.IO
Imports Inventor
Sub Main()
    ' Declare variables
    Dim controlDef As ControlDefinition
    Dim filePath As String = "C:\Temp\ControlDefs.txt"
    ' Create a StreamWriter to write to the file
    Using writer As New StreamWriter(filePath)
        ' Loop through all control definitions in the CommandManager
        For Each controlDef In ThisApplication.CommandManager.ControlDefinitions
            ' Check if the controlDef has a valid DisplayName
            If Not String.IsNullOrEmpty(controlDef.DisplayName) Then
                ' Write the InternalName to the file
                writer.WriteLine(controlDef.InternalName)
            End If
        Next
    End Using
    ' Notify the user that the operation is complete
    MsgBox("Control definitions have been written to: " & filePath, MsgBoxStyle.Information, "Completed")
End Sub
Example 2: Exporting Control Definitions with VBA
Visual Basic for Applications (VBA) is another built-in environment in Inventor, ideal for quick and lightweight automation tasks. Below is a VBA script to export control definitions:
Public Sub ControlDefs()
    ' Declare variables
    Dim fileNum As Integer
    ' Specify the file path where you want to save the output
    filePath = "C:\Temp\ControlDefs.txt"
    ' Open the file for output
    fileNum = FreeFile
    Open filePath For Output As #fileNum
        If controlDef.DisplayName <> "" Then
            ' Write the DisplayName to the file
            Print #fileNum, controlDef.InternalName
        End If
    Next
    ' Close the file
    Close #fileNum
    MsgBox "Control definitions have been written to: " & filePath, vbInformation, "Completed"
End Sub
Example 3: Exporting Control Definitions with C#
For more advanced needs, you can develop a standalone add-in using C#. This approach provides flexibility and integration with external systems. Here’s an example of a C# implementation:
using System;
using System.IO;
using Inventor;
public class ControlDefExporter
    public void ExportControlDefs(Application inventorApp)
        // Define the file path for the output
        string filePath = @"C:\Temp\ControlDefs.txt";
        // Ensure the directory exists
        Directory.CreateDirectory(Path.GetDirectoryName(filePath));
        try
            // Create a StreamWriter to write to the file
            using (StreamWriter writer = new StreamWriter(filePath))
                // Loop through all control definitions in the CommandManager
                foreach (ControlDefinition controlDef in inventorApp.CommandManager.ControlDefinitions)
                    // Check if the controlDef has a valid DisplayName
                    if (!string.IsNullOrEmpty(controlDef.DisplayName))
                        // Write the InternalName to the file
                        writer.WriteLine(controlDef.InternalName);
            // Notify the user that the operation is complete
            System.Windows.Forms.MessageBox.Show(
                "Control definitions have been written to: " + filePath,
                "Completed",
                System.Windows.Forms.MessageBoxButtons.OK,
                System.Windows.Forms.MessageBoxIcon.Information
        catch (Exception ex)
            // Handle any exceptions
                "An error occurred: " + ex.Message,
                "Error",
                System.Windows.Forms.MessageBoxIcon.Error
Identifying Vault-Related Control Definitions
When working with the Vault add-in for Autodesk Inventor, understanding the specific control definitions associated with Vault operations is crucial. These control definitions allow you to automate and streamline common Vault tasks, such as checking in, checking out, and undoing checkouts for documents.
To locate these control definitions, search for the keyword "Vault" within the control definitions list. This keyword is associated with commands in the Vault panel of Inventor. For this blog post, we’ll focus on three key Vault-related control definitions:
1. VaultCheckinTop
  • Purpose: Automates the action of checking in the current document.
  • Functionality: This control definition corresponds to the "Check In" button on the Vault panel. Using this definition, you can ensure that your work is securely added to the Vault, complete with appropriate versioning and metadata.
  • Use Case: Ideal for scripts or add-ins that require automated or batch check-ins without manually clicking through the interface.
2. VaultCheckoutTop
  • Purpose: Automates the action of checking out the current document.
  • Functionality: This control definition maps to the "Check Out" button on the Vault panel. It retrieves the file from Vault for editing and locks it to prevent conflicts or overwrites by others.
  • Use Case: Useful in scenarios where multiple files need to be checked out in bulk, reducing repetitive manual actions.
3. VaultUndoCheckoutTop
  • Purpose: Automates the action of undoing a checkout for the current document.
  • Functionality: This control definition represents the "Undo Check Out" button on the Vault panel. It discards any changes made during the checkout and restores the file's status in Vault.
  • Use Case: Essential for workflows where a checkout needs to be reversed, such as when an unintended modification is made or a file was checked out by mistake.
Ensuring Seamless Operation with Vault Options
The seamless operation of these three commands—Check In, Check Out, and Undo Check Out—relies heavily on properly configuring the Vault Options. Within these options, the Dialog Suppression section plays a crucial role by allowing you to suppress dialog boxes and define default behaviors for Vault actions. This eliminates interruptions, enabling a smoother and more automated workflow.
Configuring Vault Options
To access the Vault Options, navigate to the Vault Panel in Autodesk Inventor. From there, you’ll find a dedicated section for configuring how dialogs are handled during Vault operations.
Dialog Suppression for Automation
The Dialog Suppression settings allow you to bypass confirmation dialogs and automatically apply predefined options. This feature is essential for making the VaultCheckinTop, VaultCheckoutTop, and VaultUndoCheckoutTop control definitions work seamlessly without requiring manual input for each operation.
To enable dialog suppression, ensure the following three checkboxes are selected in the Vault Options:
  1. Check In Dialog
    Automatically confirms and completes the check-in process using the default settings.
  2. Check Out Dialog
    Streamlines the check-out process by skipping the dialog and applying predefined configurations.
  3. Undo Check Out Dialog
    Skips confirmation prompts during undo check-out operations, reverting the file to its previous version without manual interaction.
Default Options for Dialog Suppression
The Vault Options include default settings for each type of dialog suppression. These options define the behavior of the Check In, Check Out, and Undo Check Out commands when dialog suppression is enabled. While these defaults are designed for general use, they can be customized to suit the specific needs of individual users or workflows.
Driving Vault Control Definitions Programmatically
Once dialog suppression is enabled, you can write code to execute the VaultCheckinTop, VaultCheckoutTop, and VaultUndoCheckoutTop control definitions programmatically. This allows you to automate key Vault operations directly from your scripts or applications.
Below are examples in VBA, VB.NET, and C#.
The following VBA procedures demonstrate how to execute each Vault operation by accessing the relevant control definitions through the CommandManager:
Public Sub CheckInFile()
    Dim commandMgr As CommandManager
    Set commandMgr = ThisApplication.CommandManager
    Set controlDef = commandMgr.ControlDefinitions.Item("VaultCheckinTop")
    controlDef.Execute
End Sub
Public Sub CheckOutFile()
    Set controlDef = commandMgr.ControlDefinitions.Item("VaultCheckoutTop")
    controlDef.Execute
End Sub
Public Sub UndoCheckOutFile()
    Set controlDef = commandMgr.ControlDefinitions.Item("VaultUndoCheckoutTop")
    controlDef.Execute
End Sub
VB.NET (iLogic) Examples
For VB.NET, the approach is similar but uses .NET conventions and stronger type-checking. This example assumes you have access to the Inventor.Application object.
    Sub Main()
        Dim commandMgr As CommandManager = ThisApplication.CommandManager
        Dim controlDef As ControlDefinition = commandMgr.ControlDefinitions.Item("VaultCheckinTop")
        controlDef.Execute()
    End Sub
    Sub Main)
        Dim controlDef As ControlDefinition = commandMgr.ControlDefinitions.Item("VaultCheckoutTop")
    End Sub
    Sub Main()
        Dim controlDef As ControlDefinition = commandMgr.ControlDefinitions.Item("VaultUndoCheckoutTop")
    End Sub
Disclaimer: Control Definition Names May Change
The names of control definitions, such as VaultCheckinTop, VaultCheckoutTop, and VaultUndoCheckoutTop, are not guaranteed to remain consistent across different versions of Autodesk Inventor. As Inventor evolves, Autodesk may update, rename, or even remove certain control definitions to align with new features or changes in functionality.
Best Practices for Managing Control Definition Changes:
  1. Verify Control Names Before Upgrading:
    Before upgrading to a new version of Inventor, review the control definitions in the updated environment. You can do this by exporting a list of control definitions using the methods described earlier in this post. Compare the exported list to ensure the definitions you rely on are still present and correctly named.
  2. Anticipate and Test Changes:
    • Always test scripts, add-ins, and workflows in a sandbox or non-production environment with the new version of Inventor.
    • Check if Autodesk's release notes or API documentation highlight changes to control definitions.
  3. Maintain Flexibility in Your Code:
    • Use comments or documentation within your scripts to note the version of Inventor for which the control definition names were confirmed.
    • If possible, implement fallback logic to handle cases where a control definition might be missing.
  4. Update Automation Regularly:
    When upgrading Inventor, take the opportunity to review and update your automation scripts or add-ins to reflect any changes in control definitions. This ensures compatibility and reduces the risk of workflow interruptions.
By staying proactive and verifying control definition names during version upgrades, you can maintain the reliability and effectiveness of your automated workflows, even as Inventor continues to improve and evolve.
Integrating Control Definitions into Bulk Processing and Automation
By leveraging the power of control definitions, such as VaultCheckinTop, VaultCheckoutTop, and VaultUndoCheckoutTop, you can significantly enhance your bulk processing workflows and existing automation. These control definitions provide an efficient way to handle repetitive Vault operations programmatically, making them ideal for managing large sets of files with minimal manual effort.
Enhancing Bulk Processing Workflows
Integrating Vault control definitions into bulk processing workflows enables streamlined file management across multiple documents. For example:
  • Automated Bulk Check-In: After completing a batch of updates or file generation, use VaultCheckinTop to programmatically check in all files in a folder or project, ensuring all changes are properly versioned and stored in Vault.
  • Batch File Check-Out: Automate the check-out process for multiple files at once, preparing them for editing or processing without having to individually check out each file.
  • Undo Check-Out in Bulk: When working with multiple files, mistakes happen. Use VaultUndoCheckoutTop to revert checkouts for a group of files in one action, avoiding tedious manual interactions.
Adding Value to Existing Automation
If you’re already using scripts or custom add-ins, integrating bulk processing functionality with Vault control definitions can elevate your automation to the next level:
  • Batch Updates: Combine Vault commands with file property updates to process metadata, iProperties, or other file attributes in bulk.
  • Conditional Bulk Operations: Add logic to your automation to apply Vault commands only to files that meet specific criteria, such as being checked out, out-of-date, or incomplete.
  • Streamlined File Lifecycles: Use control definitions to integrate bulk file check-ins or check-outs into lifecycle transitions, ensuring Vault stays organized and up-to-date.
Whether you’re managing a multi-file project, handling large assemblies, or automating repetitive tasks, Vault control definitions are a critical component for efficient and effective bulk processing. By integrating these commands into your workflows, you can take your Inventor and Vault automation to the next level.
5 Comments
