Your Drawing Is a Hoarder (And That’s a Problem)
Welcome to the kickoff post in a series about file maintenance. Not exactly Netflix material, but trust me—your drawings are quietly collecting junk like a raccoon in a dumpster, and it’s slowing everything down.
Let’s discuss what’s in your DWG, why it matters, and how to start cleaning it up before it explodes or is passed on to someone who will instantly hate you.
First, AutoCAD Is Weird
Word and Excel are like neat little apartments. Everything’s in one file, life is good.
AutoCAD and Civil 3D? Imagine a house with secret tunnels to other houses. Your DWG isn’t just one file—it’s a combination of four places, each with its job (and potential to go horribly wrong).
The Four Places CAD Stores Stuff
1. Software Database
Your AutoCAD brain. It remembers your settings, user profile, and which tool palettes you’ve ignored for five years.
2. Drawing Database
The guts of your DWG. Geometry, layers, blocks, Civil 3D objects—this is where your actual design lives. Also, where every copy-pasted block since 2007 now resides.
3. Drawing External Database
Your drawing borrows from others—Xrefs, shape files, plot styles, and data shortcuts. If it can't find these, it panics and throws missing file errors like confetti.
4. Software External Database
The backstage crew: pipe catalogs, plot configs, support folders, etc.
Civil 3D throws a tantrum if anything's misfiled here, and the information goes on strike.
AutoCAD vs Civil 3D: The Data Difference
AutoCAD is simple. Lines, hatches, blocks. What you see is what you get.
Civil 3D is like a shapeshifter with a database. For example, a structure in Civil 3D isn’t just a structure:
  • It’s a block in plan view
  • A 3D model
  • Line work for profiles
  • A list of structure sizes and depths
  • Styled through a catalog that lives in a hidden folder three directories deep
  • Driven by settings you didn’t even know existed
All of that comes together to make one manhole. Now multiply that by an entire network and you see why Civil 3D files can be so heavy.
Why Does Stuff Show Up Twice?
Do you ever wonder why plot styles or shape files appear in the drawing and the external database?
Here’s why: the DWG knows what it wants. But it doesn’t have it.
That stuff lives outside the file. So the drawing says,I need A.ctb,and the software says,Cool, where is it?If the answer isI dunno,you get broken plots, weird styles, or missing fonts that render your sheet with Wingdings.
How This Helps You
Knowing where the data lives means you can fix issues like:
  • Slow files
  • Plot errors
  • Missing labels
  • Broken parts
  • Drawings that cry when you open them
It also helps you avoid being that person—the one who sends out a 280MB file with 47 missing references and a font last seen in Windows 95.
Wrap It Up
Look, your DWG is carrying a lot: layers of geometry, styles that haven’t been touched since 2010, ghosts of Xrefs past, and Civil 3D, which is basically a database wrapped in geometry.
This post sets the groundwork. In the next ones, we’ll start tackling how to clean files and keep them clean. Cleaner files = faster work = fewer support tickets = happier you.
Stay tuned. And stop copying random blocks from mystery files. Seriously.
1 Comment
TiStars
Thanks for sharing and look forward to your next ones!
