Tips & Tricks - How to module an A-frame/ gable / double / 2 waters roof
  1. Create 3D sketch
  2. Draw a polygon on top of the area you want to design the roof
  3. Select the surface and extrude it if you want the lowest attic floor to have some "vertical facade" before it tilts.
  4. Draw the roof ridge with the line tool and move the line up 😀
Watch the whole workflow in the video
