Revit Hints and Hacks: Orient Your 3D View
Occasionally, you may rotate your project to show True North. This can cause your 3D view not to show you a straight look at your building in FRONT or RIGHT views.
Getting the 3D cube oriented to your building is simple if you have a named elevation.
Once that is set, you can see how the project is squared up with the cube.
 Hope that straightens things out for you!
When it comes to any blog post, sing it with me now, “If you liked it then you shoulda put a “Like” on it.
#CADMama #AutodeskCommunity #AutodeskExpertElite #Revit #3DOrientation
Donnia Tabor-Hanson, aka CADMama
Revit Family Counselor
Twitter @DonniaTH
1 Comment
