PC Build for Inventor
PHalllo
588Aufrufe
0Antworten
Nachricht 1 von 1
PHalllo
hello, I have been struggling with inventor and my laptop for several years now. Now I want a PC. Is it possible that you can give me some tips for this? I have read professional Quadro graphics cards from Nvidia or AMD Pro cards are optimal. But I did not want to spend so much. It should already be an Nvidia graphics card because Matlab probably works well with the CUDA. It should also be a CPU with high single thread performance, because Inventor does a lot of work on only one core. And also an Intel CPU again because of matlab and MKL. I also got this Info: "While the 10600k has a higher boost clock speed, that doesn't mean it will have better single threaded performance than the 3700X. The reason is Zen 2 based CPUs have about 10% higher IPC than Sky Lake derived Core CPUs, that means that on average a Core CPU will need to clock 10% higher to equal the performance of the Zen 2 CPU. Is that a hard & fast truth, no, but on average it works out that way. Overall the Single Threaded performance between the 3700X & 10600k will be a wash, but if something is multi-core the 3700X will generally be faster." i have a first compilation. Still without Nvidia graphics card, because I haven't found a suitable one. https://de.pcpartpicker.com/list/9FyQWb Maybe you can help me there. And to give some hints to the single parts, it is my first selfmade PC. Thanks
0 „Gefällt mir“-Angaben
589Aufrufe
0Antworten
Antworten (0)
