Where are the codes for the command "create subassembly from polyline"
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/...
In the dialog box of the command "Create subassembly from polyline", where is the bracket "code link:" ?
I can´t create a corridor surface from a specific code link because I can´t put a code link for this generated subassembly.
[quote]
  • Multiple: Creates a new link for each segment created from the object selected. This is useful for assigning link codes to different components of the subassembly for creating surfaces, or other display features.
  • Single: Creates one link from all segments created from the selected object. This is provided to make creating shapes simpler. Using the Add Shape right-click command, you only need to perform one action.
  • None: Produces no links; only points will be created at the vertices.[/quote]
In Multiple or Single, we would able to put a code link and a code point.
In "None" type, we would able to put a code point.
1 Comment
joantopo
Answer Day
Rail Community
