Vanilla Commands versus Civil3D Commands
How hard would it be to make some of the everyday editing commands that are civil3d specific but be able to used in a vanilla fashion?
These are just some of the ones come to mind. (Civil3d to Vanilla)
_AeccBreakFeatures to Break
 _AeccTrimFeatures to Trim
_AeccJoinFeatures to Join
_AeccFilletFeature to Fillet
_AeccReverseFeature to Reverse
_AeccInsertFeaturePI to Pedit
These are just some.... I know there's got to be away where we can just type a command ( break ) and it can break vanilla objects and the 3D objects.
Can one command perform an (either-or) fashion?
User types Break, and selects a polyline and can break it, but with the same command the user selects a feature line and it can do a _AeccBreakFeatures?
2 Comments
rkmcswain
You can probably do this with custom programming.
For example, I created a command named ET for Editing Text, and the code launches the correct editor for whatever you select (Text, Mtext, Rtext, Attrib, C3D Label, ArcAlignedText, etc.).
BlackBox_
I did something similar for my BAP (Break At Point) routine, which has always allowed for repeated entity + point specification (via WHILE loop), as well as CONDitionally supporting Lines/Polylines (aka Curves), and now Feature Lines.
Custom programming is the quickest way to get at what you're after, but I agree that Civil 3D *should* have supported the vanilla Commands since inception.
Sent from my iPhone
Answer Day
Rail Community
