Update a single point in a drawing & have it update in the survey database
When you have the survey database open and unlocked for editing in your drawing your option changes from having the ability to 'edit point' to 'edit points' and when you select your point to edit it,  you have to fish for your 1 point out of 100 points in the survey database editor...
If I'm open for editing and unlocked I should be able to move my point, change it's elevation, change it's description, change it's user defined classification property, etc. and when I'm done it updates in my drawing and in my database. If I'm unlocked, it should automatically update in my database without even having to check it back in, but even a check-in would be fine as long as I could simply edit one point at a time.
Answer Day
Rail Community
