Unable to delete unused User defined Expressions.
Expressions are marked as referenced, as soon as created.
Unable to delete the Expressions, which are no longer required/created mistakenly.
This will lead to garbage accumulation in the template files based on these Label styles.
Users shall be permitted to delete.
5 Comments
doni49
What version are you using?  I just tested it in C3D 2023 and was able delete the expression without an issue.
I am using C3D 2024
ACADVER = "24.3s (LMS Tech)"
Also, The expressions are not copied, while the Styles using the expressions are copied into another drawing
It seems the the problem persists only for some groups only.
I checked in Turnout labels, I am able delete the expressions.
doni49
That's really odd.  I opened C3D 2024.3 and added an expression.  Then I deleted it with no problem.  I thought maybe that was just because nothing had ever referenced it.  So I set the a style to use the expression for the Text height.  Just on a whim, I decided to see if I could delete the expression even though it was referenced in the style.  It did in fact let me delete the expression.  I used the undo command to bring the expression back.  Then I checked the style and it was in fact set to use the expression for the text height (I thought maybe I hadn't saved the style setting).
Then I thought maybe it was because I hadn't USED the style.  So I made sure that there was a label using the style.  It still let me delete the expression and the label height stayed the same.  When I looked at the style definition, the text height had changed to the VALUE that the expression previously used.
This definitely seems like a bug.
Please see this thread to access my test dwg file (https://forums.autodesk.com/t5/civil-3d-forum/unable-to-delete-unused-user-defined-expressions/td-p/... ).
Answer Day
Rail Community
