TRIM COMMAND IMPROVEMENT
Dear sir,
When we use trim command there is no option for trim from one point to some distance to enter.
Mean from one point to 100mm.If i want trim 100mm line from one point then we have no such option.
Thanking you.
1 Comment
rkmcswain
Hi.
First off, this is the Civil 3D Ideastation, and that development team has nothing to do with the core AutoCAD commands, such as TRIM.
Secondly, it sounds like you want the LENGTHEN command. You can use it to add or remove "X" amount from an entity.
Answer Day
Rail Community
