Hi.
When I have a TIN volume surface I generally want to add "surface spot elevation labels" of that surface. However I have to pick in the drawing each point.
It would be interesting if the same command had an option to select locations by selecting a group of points graphycally, so C3D add automatically labels in the location of that COGO points. (or for example, in the vertex of TIN lines of a selected surface).
options:
- Select a Point group.
-Select points graphycally.
-Select a surface (to add in its vertex).
Thanks.
