Surface Context Ribbon: Modify panel> Surface Properties Styles Submenu
I'd like the Surface Context Ribbon's Modify panel>Surface Properties item to show a sub-men that allows me to change which style is assigned to the selected surface.  Here's a mock-up of what I'm suggesting.
5 Comments
troma
You can switch styles pretty quicky in the properties pallet.
joantopo
And adding that property in the quick properties.
I think that it´s the fastest way to choose surface´s styles.
doni49
I keep Properties toolbar docked out of site.  So I tend to forget about them.
Also while they're add it (and in fact, this would probably be even more useful than the ribbon item version), please add a similar option to the Toolspace menu (see the mock-up below).
I say that this might be even more useful because if the surface is currently assigned to a "No-Display" style, then there's no surface object that I can select.  I currently have to right click the surface, click on surface properties, change the style, select ok.
troma
Or in prospector > right-click the surface > Select > change the style in the properties
doni49
"Or in prospector > right-click the surface > Select > change the style in the properties"
Now that's helpful too.  🙂  It's still not quite as good (IMHO) as putting it in a sub-menu but it comes a lot closer.  Thanks!
Answer Day
Rail Community
