Increase the limit of the point number supported by Subassembly Composer expressions and API. Add support to the points with the numbers higher than 1000 in Subassembly Composer Expressions and fields in properties.
At the moment, when a point with a number > 1000 is referenced in an expression, a message about compiler error shows up.
Increasing the limit could help to adjust the geometry or use more conditions to better suit the needs of the user.
