Support points with number higher than 1000 in Subassembly Composer
Increase the limit of the point number supported by Subassembly Composer expressions and API. Add support to the points with the numbers higher than 1000 in Subassembly Composer Expressions and fields in properties.
At the moment, when a point with a number > 1000 is referenced in an expression, a message about compiler error shows up.
Increasing the limit could help to adjust the geometry or use more conditions to better suit the needs of the user.
3 Comments
f_furger
This is a super idea that I support very much!
TimYarris
Thank you for submitting this idea. The development team will review it while customers continue to add feedback and vote for it.
FURKAN.TARAKCI-DLSY
I agree, it also needs improvement against freezing and stuttering.
Answer Day
Rail Community
