Not entirely sure whether this is the right forum to post ( because we don't have a AutoCAD idea forum like Civil 3D ideas forum), but anyway I just give it a shot here.
First, I'm writing Civil 3D plugins rather than AutoCAD plugins, but since Civil 3D is built on top of AutoCAD architecture, and this is an architectural issue, I figure that it should be solved at AutoCAD level, hence here.
The issue is that we need to be able to use AssemblyLoadContext internally within AutoCAD/Civil 3D for our plugin, just like Inventor. For precisely the very same problem. This is very important because different plugins can have same dependency DLLs ( say System.Text.Json.dll), but different version, which results in DLL hell.
From what I can tell, subclassing AssemblyLoadContext and keep a reference to it in the concrete class inheriting IExtensionApplication should work... in theory. But in practice, the all important Load method is simply not being called ( I've tested it so I know). This is why I said that it's not supported at the moment
Some of the related issues that I can find on the forum:
I'm aware that we have some sort of workarounds, but I feel that they are inadequate. Let me address them one by one.
Revit seems to have a hot discussion on this internally. So AutoCAD/Civil 3D should also have this feature.
PS: I've opened up an internal feedback item on this. Hopefully those can, will go and vote on it too.
