Structure style (section). Display as boundary does not update the boundary if you rotate the structure in plan.
Hi.
If you have a structure and you rotate it (in plan view) and then you show that structure in a Section View, if the structure style (section tab) is set up as "Display as boundary" then that boundary does not update and you are seeing that structure wrong in the Section View.
Solution is changing to "Display as solid", but not a way to update the boundary if that structure is rotated in plan view?
3 Comments
TimYarris
Hi @joantopo . This seems to have been resolved in 2023. Would you please confirm?
joantopo
Yes, it works fine in 2023. Thanks!
TimYarris
Thanks for confirming, @joantopo!
Answer Day
Rail Community
