Storm and Sanitary Analysis Subbasin Curve Number Description and automatic area calculate
I can't type with spaces in the Description column of the Subbasin Curve Number tab.
I'd also like to see a button somewhere on the curve number tab which I could hit to calculate the remaining area based on the total area from the physical properties tab.
For example: I have two sub areas with different curve numbers of a total area of 10 acres. I've already entered one with 4 acres, it'd be nice to have a button I can hit for the other sub area that would calculate the remaining area (10-4 = 6 acres). This would easily get the total area to 100%.
3 Comments
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it
matt_anderson_pe
SSA does autocalculate area if you add your percentages up to 100%
cdemingHUAQU
Yes, but it doesn't auto calc the remaining area or percentage. If I have 2 areas and I've already entered the 40% area, the 2nd area should auto fill in the remaining information of area and percentage.
Answer Day
Rail Community
