Split Profiles - Allow Label for Spanning Segment on Both Views
When I split my profile across multiple Profile Views, invariably, there is a segment that is shown on (at least) two Profile Views.  But C3D will only allow the segment to be labeled ONCE.  When a segment spans across multiple Profile Views, please allow the label(s) for that segment to be shown on each Profile View.
3 Comments
kssnuggle
This same problem exists in pipe networks. Storm and sanitary.
jeffl
This should be a standard feature. I can't remember a project where this hasn't come up. I created a label style for profiles and pipes that allows me to drag the copy to the second profile view, this is only a work-around.
sirjoelsph
@doni49 This is already possible - you just need to use the "in view" options for profile labels.  To label my tangent grades, I draw an invisible line from "Anchor Tangent Start In View" to "Anchor Tangent End In View" and then place my tangent label at the midpoint of that line.  I use similar settings for vertical curves as well.  These ensure that a label is always present no matter where a profile view starts or ends.  Unfortunately, these same options don't exist for pipe networks.
Answer Day
Rail Community
