showing properly the output parameter value
I don´t know if it´s a bug.
For some reason, if we have a subassembly with output parameters, the output value is the reverse of the input parameter value.
Look at this example:
input parameter = 2:1     (horizontal / vertical)
output parameter = 0.50 = 1: 2
Luckily the another subassembly gets this value correctly but people could be confused with this showed value.
It happens the same with grade:
input parameter=  + 2%
output parameter = -2%
4 Comments
doni49
As the person designing the SA, you control what it outputs.  Before declaring it as a bug, I'd like to examine the pkt file.
My point in transition SA takes a cross slope as an input parameter, performs some calculations and then returns an output parameter showing what the cross slope is at the current station.  I don't remember experiencing what you've described.
joantopo
Sorry, it is only with custom subassemblies.
This is a basic custom subasssembly made with SAC 2015.
 http://www.mediafire.com/download/21rnbt14470rbr1/test_outputs.pkt
In Civil 3D, Slope_OUT appears with "0.5"
doni49
"It is not related to custom SA.
It happens the same with stock subassemblies."
Ouch!  I didn't realize that's what you were saying.  I saw SAC in the image you posted and thought you had created the SA.  And since I don't understand spanish, I couldn't check anything else about the image.
joantopo
I think that I know what´s the reason:
if a slope value (slope type) is returned in double type, then is the reverse value.
For example, if you want to use a slope such as 2:1  in "Delta X" for some point, you must type this: 1/ slope.
Then the subassembly in SAC calculates this 1/0.5= 2
So, I think that the reason is when the slope is converted to double value.
Answer Day
Rail Community
