sheet set manager sheet number as a suffix
the agency we work with requires the layout tabs and file to have a 4 digit number to order the sheets. If we use page numbers, printing to a pdf sort the sheets for the page number when it need to sort by the 4 digit order.
In ssm we get
01-0101_ti
01-0203_ts
02-0203_ts
01-0302_mq
02-0302_mq
As you can see, the 01-mg sheet ends up before the 02-0203_ts when sorting by file name. It would be nice to have the sheet number as a suffix
0101_ti-01
0203_ts-01
0203_ts-02
0302_mq-01
0302_mq-02
1 Comment
AdammReilly
In general, we should be able to select the output pdf name based on a myriad of SSM properties.
For example, Title-Number; Number-Title; Number-Description; Number-Title-Description; Number-CustomPropertyX-Title.
We should also be able to choose the string between each property.
Answer Day
Rail Community
