The goal is to be able to share custom subassemblies easier using tool palettes. Thanks to Civil 3D 2024, this is far easier now that before, but I think it could be even better.
Please allow us to remove the hard-coded path to the PKT file and allow the AutoCAD support files search path setting to find it. A municipality or other organization could package a tool palette containing PKT files and as long as the path is stored in the search path, all would work well.
I'll explain...
When blocks are added to a palette, theirs paths are hard-coded.
The path to the block can be removed and if that path is stored in the AutoCAD support files search path, the block is found. Removing hard-coded paths provides a more streamlined way to share palettes.
Currently, subassemblies added to a palette have a hard-coded path. However, if I remove the path and add that path to the search path, the PKT is NOT found, unlike blocks.
