Share the same alignment for OffsetAssembly and the BaseLine.
Sometimes, we have to make a project with 2 platforms in different levels each one.
Both platforms are parallels in plant and different in elevation: delta Y
I use "OffsetAssembly" in the left side of the assembly to add subassemblies (left platform).
Then I can use "MarkedPoint" and "LinKtoMarked" to join them.
However, there is a limitation in the Corridor, and it is that I cannot use the same aligment for the BaseLine and the OffsetAssembly:
I would like that Autodesk staff consider this limitation and solve it because then we could draw in the same profile view 2 profiles (the left side and the right side profile for each platform).
Moreover, some operations to have a main design profile and a child design profile (they will be always parallel in delta Y). The child design profile will be dynamic if I edit the main design profile.
This is more practise than to have to create a new alignment (in general an offset alingment) and create a design profile in another profile view.
Answer Day
Rail Community
