Setting the slope pattern direction
When we select a pair of corridor FL to define a Slope pattern it can happen that both corridor FL generate an horizontal plane (0% grading)
Actually, my custom subassembly (retaining wall + slope), generates a cut slope back to the retaining wall and I programmed some scenarios when the slope had to be 0% grade.
As you can see in the image, the slope pattern when the grade is 0% is in the opposite side.
It would be interesting some setting in the software to change the side when grade is 0%
Answer Day
Rail Community
