select with shift
select with shift
Hello. It will be good, if it could possible to select more items in every dialog box with shift. For expamle, when you want to project object into multiple section view you can't select easily with shift or ctrl, you only can select one at the same time. (Neither in the main dialog box and neither in the source layers option. It is so annoying.) Many thanks if you check and fix it.
1 Comment
TimYarris
Thank you for the idea. We will do our best to implement this as we make enhancements to the dialogs.
Answer Day
Rail Community
