Sample Lines from a Feature Line used as corridor baseline for Quantity Takeoff
Hello-
Since we can build corridors from Feature Lines these days, it would be very helpful if we can use the same C3D Quantity Takeoff tools we currently have for corridors built from Alignments\Profiles.  Currently, you can't create sample lines from corridor baselines built from feature lines.
Not being able to generate samples lines from a Feature Line baseline is annoying since you have to create an alignment from that corridor just to generate some sample lines to perform a Quantity Takeoff Criteria for earthwork or corridor structure material volumes.  Seems like if we can use a feature line as a corridor baseline...all the other tools that work with corridors built from alignments/profiles should work too.
Thanks for your consideration and time reviewing this idea.
Answer Day
Rail Community
