SAC: new column "Trackbar_scroll" if it was a slider volume control to change the value of Input parameters
Hi.
In SAC in the preview window, we can just pick on a point or Link to highlight it in the Workflow window or drag Surface, Horizontal or elevation targets.
We cannot move a point in the preview window as we can do in Templates of ORD when the Point has 0 or 1 Constraint.
Due to we cannot move a point in the preveiw window it would be interesting if we could change faster the value of the input parameter, so I would like to see a new column, next to the "Default Value" column, called "Trackbar Value" which will be a trabkar-scroll control (similar than a slider Volume Control).
If we type a point on the "Default value" cell then the trackbar updates automatically. If we slide the trakcbar then it shows the calculated value in the "Default Value" column.
This way if we drag the slider in the trackbar we can see dynamically how the preview window changes.
Answer Day
Rail Community
