SAC: more improvements.
-If we make a "Decision" with an inexisting point, SAC doesn´t consider a mistake.
For example, the following Decision:
AP3.DistanceToSurface(TN)>0
But AP3 doesn´t exist in our subassembly...
So, before I can use a point in the Decision, previously it must exist, if not then SAC warns about this mistake.
-We can create an "Auxiliar Link" (or "Link") but  not using auxiliary points. Currently, to define an "auxiliary link" must have with 2 Points (no auxiliary points).
8 Comments
joantopo
It happens the same with the "Start Station" and "End station" of a "Surface Link" (or Auxiliary Surface Link).
You can type an inexisting point but SAC doesn´t consider an error.
joantopo
wish: no Report messages for Intersection points.
I am using "Intersection Points" to check if 2 links are crossed each other, but if they don´t cross then the "IntersectionPoint". IsValid= False and automatically this subassembly will send a report message to the event viewer.
I use IntersectionPoints to get the intersection between a link and a surface link in this case, but I don´t mind if the IntersectionPoint.IsValid= False because I only use the "IsValid" in the Decision.
I don´t like this or at least I was be able to set this behaviour. (checkboxColumn in the DatagridView to enable or disable them)
doni49
Sure you can......
joantopo
Well, I think that this is new in SAC 2016.
I tried with SAC 2015 and I couldn´t.
joantopo
And about disable Report messages is solved like @doni49 said:
In the same point properties there is the checkbox "Show errors"
joantopo
This is OK:
SAC warns to us. (we can´t create new points from inexisting points)
SAC doesn´t warn to us in some expresions:
-Start X or End X in a surface link.  (Start X= P5.X)  and P5 doesn´t exist.
-In a decision, for example (P5.DistanceToSurface>0)   P5 doesn´t exist..
Perhaps, the reason is to not to lose this settings because when we break a branch, in the first case, the selected point is removed, although when you join the branch again, it recovers the previous point.
doni49
I used to it in 2014. I don't have access to 2015 so I can't test.
joantopo
Another thing:
If we use some variable, for example a string variable. If we use it in some code point (or code link, code shape), and then we change the name of the variable, SAC doesn´t warn to us that the variable in the code point doesn´t exist.
See the following example:
The variable "codificado" was created and used for the point code (P2), but later, this variable was renamed to "codificado2".
SAC doesn´t warn to us that "codificado" var doesn´t exist.
It happens very often when we copy and paste a variable, because the variable is automatically renamed wit the sufix "_copy", for example "codificado_copy".
Answer Day
Rail Community
