Retaining Wall Subassembly meeting the Existing Ground
Because Civil 3D does not process vertical faces in the construction of surfaces the way the retaining walls are defined defeats their use. Either make Civil 3D to use vertical elements or rebuild the subassemblies to have a slant on the outside wall so that it would work correctly. I would prefer the first one also. That way I can use feature lines on top of other:)
1 Comment
Status changed to: Archived
Due to a low strategic fit, technical feasibility, or the support of your peers, ideas with this status are not being considered for implementation at this time. Thank you for your contribution, every idea has merit. We always encourage you to rework and resubmit these ideas based on feedback received.
Peter Funk
Sr. Product Manager
Autodesk, Inc.
Answer Day
Rail Community
