Retain width for the dialog for the next time.
When we open the Parameters tab (Corridor Properties) to choose an assembly of a Region, it shows a dialog as you can see in the following image:
We can edit the width of this dialog but C3D does not retain this width for the next time.
If the name of my assemblies are long names then I have to change the dimensions of this dialog every time...
This dialog should have an assembly PREVIEW (it´s a MUST HAVE) similar to the preview for labels or blocks.
And a "edit subassembly name" directly from here.
And also a assembly regions QUERY to check if the selected assembly is also assigned in another regions of our corridor.
In this dialog box should show a list of the region´s name that they have that assembly.
Moreover, this option (change assembly of the Region should be also in the context ribbon of a corridor as we can do to change the frecuency or targets directly without opening always the corridor properties..
Answer Day
Rail Community
