Replace FeatureLine to another one as targets in the corridors.
Example:
We have a FL called "FL-1" in the corridor 1 (region 2, region 3 and region 5) as offset target.
We also have this FL as offset target and elevation target in corridor 2.
Now, we draw a new FL (FL-2), and we want a command to replace that FL as target in all corridor to this new FL.
This command ask us:
-Select original Feature Line to replace it (we select FL-1).
-Select new Feature Line (we select FL-2).
-A dialog box showing all corridors to check one or all of them.
If "MinimumDistanceBetweenSurfaces" doesn´t generate a dynamic FeatureLine, at least we can replace the old featureLine (we converted the polyline to FL) to the new FL if we call again this command.
1 Comment
joantopo
I have been thinking about this and maybe, a better way would be updating vertex of the old FL from the new FL.
So, instead of changing the entity in the Target Mapping, I update the data (vertex and elevation points) in the current FL which is already being assigned as a target.
I can do this from C3D API.
However, I have to do another command which should be called first to put all the corridors in "no auto-update" status temporarily while I am doing this.
Answer Day
Rail Community
