Remove Survey DataBase
In the ToolSpace, Survey Tab, when we do right button to an existing Survey DataBase to show the context menu, there is not the option: Remove Survey DataBase.
We have to do this manually:
-Close the Survey Database first and open the job folder, to select the folder about the Survey DataBase and remove it.
I would like to do this operation directly from Civil 3D without browsing to the job folder.
Even, if we select this option: "Remove Survey DataBase" with a open Survey DB then Civil 3D should close the Survey DataBase first automatically.
If you want, C3D could warn about this with a dialog box (Yes/No) asking about if the user is sure to remove it.
1 Comment
Excellent idea, just what I'm looking for.
Answer Day
Rail Community
